grubik
Aug 22, 2025Tutor
GS724TPPv3 (FW v6.1.0.10) PoE MIBs error
Hi, I'm trying to check/enable/disable PoE on switch ports via SNMP. The problem is that I'm using MIBs for firmware version 6.2.1.12 but my switch has firmware version 6.1.0.10 and I do not wish to...
- Sep 02, 2025
Solution was to update Firmware to the latest version and download latest MIBs.
grubik
Sep 02, 2025Tutor
