RickyLW2024
Apr 25, 2024Aspirant
GS724TPv2 Disconnecting from network
Hello, I am after some adivce with a family members network. I am not familar with NetGear switches and there GUI interface. The current setup is Internet in to Main Switch Unify-USW Pro 24 PoE t...
schumaku
Apr 29, 2024Guru - Experienced User
Look into the Spanning Tree config on other device, the USW Pro 24 PoE as well as on all GS724TPv2.
Logs are always informative, at least as long as you can establish some connection to the devices. Industry common is to bring up a syslog server on the network, and collect all the syslog output from all devices.
- RickyLW2024May 01, 2024Aspirant
Thanks for this, have since been to site and found out its L2 Loop Protection disabling the ports. Have since checked over and elimated a few issues that might be causing this. Apreciate the advice!
