Rbmrk
Aug 08, 2024Aspirant
GS724TPv2 link issues
Hello, New to this forum, in hope of finding some guidance and solution to my issue, I have a GS724tpv2 switch where i have links issues, one Access point connected via POE rest is random clients, ...
schumaku
Aug 09, 2024Guru - Experienced User
Welcome to the Netgear Community!
For whatever reson the Ethernet link keep bouncing ... physical, cable, AP issue.
Tell us more about the AP make and model please.
TIA,
-Kurt.
PS. This isn't a Managed Switch model, much more a Smart Managed Switch to be discussed in the Plus and Smart Switches Forum section - I'll request moderator to move your thread accordingly.
- RbmrkAug 25, 2024Aspirant
Seems that its not only the AP that is getting this issue, many of the other links is bouncing up and down, could be of faulty firmware that was upgraded recently? 😞
- WillatbitsAug 25, 2024Aspirant
I met the same things ,Even I never update firmware .I updated firmware today .But the same .
I set 6 of GS724 TPv2 (Firmware Version V2.0.8.17) in the new building .
I set up the local network and connected 40 cameras and three APs for testing, and I could access them remotely. Power engineers may still be tweaking plans, so there are always some unusual outages and restarts out there. I noticed that. After every abnormal power outage, the ports connected to my APs and the ports connected to the main switch will most likely not work. But when I got to the site, I completely unplugged the power again, rebooted the switch, and the ports will work well again,
This is very strange. I have 20 PoE cameras connected to one switch. After restarting that Poe switch remotely, I can see that only 10 ports are online status through the web management interface, but in fact the status lights of their ports are flashing on the front of switch, and I can check it in real time. All cameras live View can be showed on recording server
I searched a lot of information about the cases of lost port connection on this model of switch. Many people have encountered similar situations but have not found a solution. I am disappointed with the brand netgear
