Adam1976
Dec 10, 2024Aspirant
GS724TPv3 setting up routing between different VLANs'
I'm a new user of the switch. I'm trening to setup VLANs'. I cannot find a way to setup on this switch a routing between different VLANs' and also define the IP addresses range for each VLAN. Y...
- Dec 11, 2024
Hi Adam1976,
Welcome to the NETGEAR Community! 🙂
Not all of the Smart Switch supports intervlan routing. The GS724TPv3 is one of the model that does not have support for this. If you require intervlan routing with PoE, you may want to consider the GS728TPv3, GS728TPPv3, GS752TPv3 or GS752TPPv3. Please see datasheet below for more information:
If you also require the switch to have DHCP server where you can define the IP addresses range for each VLAN, that would be available in Fully Managed switches M4300, M4350 and M4250.
https://www.downloads.netgear.com/files/GDC/datasheet/en/M4300.pdf
https://www.downloads.netgear.com/files/GDC/M4350/M4350_Datasheet.pdf
https://www.downloads.netgear.com/files/GDC/M4250/M4250_Datasheet.pdf
Have a lovely day,
RennaD
Netgear Team
RennaD
Dec 11, 2024NETGEAR Moderator
Hi Adam1976,
Have a lovely day,
RennaD
Netgear Team
schumaku
Dec 11, 2024Guru - Experienced User
Mea culpa, looks I was wrong. Kudos to RennaD for the hint.
While the user manual does mention routing in various places, the ubiquitous Routing section does indeed not exist in the user manual.
However, miselading are sections like these:
Sorry,
-Kurt.
- RennaDDec 12, 2024NETGEAR Moderator
Hi schumaku,
I came accross this on the manual as well when I was checking, but noticed that it was for IPv6 ACL configuration.
Hi Adam1976,
We’d greatly appreciate hearing your feedback letting us know if the information provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Have a lovely day,
RennaD
Netgear Team
