Adam1976
Dec 10, 2024Aspirant
GS724TPv3 setting up routing between different VLANs'
I'm a new user of the switch. I'm trening to setup VLANs'. I cannot find a way to setup on this switch a routing between different VLANs' and also define the IP addresses range for each VLAN. Y...
- Dec 11, 2024
Hi Adam1976,
Welcome to the NETGEAR Community! 🙂
Not all of the Smart Switch supports intervlan routing. The GS724TPv3 is one of the model that does not have support for this. If you require intervlan routing with PoE, you may want to consider the GS728TPv3, GS728TPPv3, GS752TPv3 or GS752TPPv3. Please see datasheet below for more information:
If you also require the switch to have DHCP server where you can define the IP addresses range for each VLAN, that would be available in Fully Managed switches M4300, M4350 and M4250.
https://www.downloads.netgear.com/files/GDC/datasheet/en/M4300.pdf
https://www.downloads.netgear.com/files/GDC/M4350/M4350_Datasheet.pdf
https://www.downloads.netgear.com/files/GDC/M4250/M4250_Datasheet.pdf
Have a lovely day,
RennaD
Netgear Team
RennaD
Dec 11, 2024NETGEAR Moderator
Hi Adam1976,
Have a lovely day,
RennaD
Netgear Team
Adam1976
Dec 17, 2024Aspirant
Thank you for valuable information.
I've learned in a bit hard way what is meant by: "VLAN routing : N/A" in the documentation on the page:
https://www.netgear.com/business/wired/switches/smart-cloud/gs724tpv3/
