adamtvogt
May 14, 2025Follower
GS724TPV3 wide open?
Hey there, I bought a GS724TPV3 just for the POE functions with having the management option in the future. I need to learn more about management. Until then, how do I just open all of the ports with...
schumaku
May 15, 2025Guru - Experienced User
Yes, in it's default configuration it behaves like an all open switch, all data is associated internally with the VLAN 1.
One notable difference is (when I have it right) is that the Spanning Tree (STP, or the compatible RSTP) protocol is enabled by default. Please double check it's really RSRP active, because of he legacy STP (some 25 years+) old industry requires much more time after fixing loops. RSTP re-establishes the network connectivity on less than one second.
Hope you realize there is a lot of technology in such a "simple" switch - for reasons the documentation does span over several hundred pages.
Welcome to the Netgear Community adamtvogt, and good luck where ever you are.
Regards
-Kurt.
Switzerland, and not associated in any form with Netgear
