Adam1976
Dec 10, 2024Aspirant
GS724TPv3 setting up routing between different VLANs'
I'm a new user of the switch.
I'm trening to setup VLANs'.
I cannot find a way to setup on this switch a routing between different VLANs' and also define the IP addresses range for each VLAN.
Your help will be highly appreciated.
Hi Adam1976,
Welcome to the NETGEAR Community! 🙂
Not all of the Smart Switch supports intervlan routing. The GS724TPv3 is one of the model that does not have support for this. If you require intervlan routing with PoE, you may want to consider the GS728TPv3, GS728TPPv3, GS752TPv3 or GS752TPPv3. Please see datasheet below for more information:
If you also require the switch to have DHCP server where you can define the IP addresses range for each VLAN, that would be available in Fully Managed switches M4300, M4350 and M4250.
https://www.downloads.netgear.com/files/GDC/datasheet/en/M4300.pdf
https://www.downloads.netgear.com/files/GDC/M4350/M4350_Datasheet.pdf
https://www.downloads.netgear.com/files/GDC/M4250/M4250_Datasheet.pdf
Have a lovely day,
RennaD
Netgear Team
Adam1976 wrote:
I cannot find a way to setup on this switch a routing between different VLANs'Start here https://www.netgear.com/support/product/gs724tpv3/#docs and consult the fine 24-Port Gigabit Ethernet (Hi-Power) PoE+ Smart Switch with 2 SFP Ports and Optional Remote/ Cloud Management GS724TPv3 GS724TPPv3 User Manual.
Adam1976 wrote:
and also define the IP addresses range for each VLAN.Nothing the like required.
- RennaDNETGEAR Moderator
Hi Adam1976,
Have a lovely day,
RennaD
Netgear Team- RennaDNETGEAR Moderator
Hi schumaku,
I came accross this on the manual as well when I was checking, but noticed that it was for IPv6 ACL configuration.
Hi Adam1976,
We’d greatly appreciate hearing your feedback letting us know if the information provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Have a lovely day,
RennaD
Netgear Team
- Adam1976Aspirant
Thank you for valuable information.
I've learned in a bit hard way what is meant by: "VLAN routing : N/A" in the documentation on the page:
https://www.netgear.com/business/wired/switches/smart-cloud/gs724tpv3/
