Semen_Petrov
Oct 18, 2021Aspirant
GS724Tv3 Can't generate text configuration
Can't generate text configuration. choose "Maintenance", next "download", next "HTTP File Download", next "Select File", next create a file with the extension "*.stk" This file is not intended for...
schumaku
Oct 18, 2021Guru - Experienced User
Do you intend to retrieve the current config file from the switch or do you have a backup config you like to push to the switch?
Be aware Netgear used a confusing logic for upload (from the switch to the computer) vs. download (from the computer to the switch) on this older switches.
Semen_Petrov
Oct 19, 2021Aspirant
I intend to retrieve the current config file from the switch
- schumakuOct 19, 2021Guru - Experienced UserSuspected this. On this older Netgear switch Web UI you need to use the Upload (switch to computer) control.
- schumakuOct 25, 2021Guru - Experienced User
Don't worry Semen_Petrov , us "young" networking people often hit this on the old UI design. It was aparently designed by a Professor in Physics. "Imagine you sit on that point in the switch and see things around you. ..." Took me a while to get this logic changed on the early implementatins of the new UI. And I'm approaching 60 years 8-).
