K1XH
Oct 19, 2013Aspirant
CLI User Manual for GS724Tv3?
Is there a CLI Reference available to download somewhere for the GS724T series of switches?
(great forum here BTW, very helpful so far!)
Micky
- I think smart switches with no console port has no command options.....
- evbGuideDid you try the support website: http://support.netgear.com/product/GS724Tv3
- jmizoguchiVirtuosoI think smart switches with no console port has no command options.....
- K1XHAspirant
evb wrote: Did you try the support website: http://support.netgear.com/product/GS724Tv3
Yeah, tried that. Plenty of web interface support, nothing about the CLI.
I wonder if the older models had a reference manual? - K1XHAspirant
jmizoguchi wrote: I think smart switches with no console port has no command options.....
It is easy to telnet to these switches. Just because there is no console port doesn't mean no CLI access... - K1XHAspirantI also wonder if the CLI reference for the 7200 series might apply?
Micky - rjtTutorWhen logged into the web interface of the GS724TS, goto "Maintenance" --> "Troubleshooting" --> "Remote Diagnostics" --> Click the "?" for HELP.
"Enable - Enable the ability to create a Telnet session to the device."
Tried telnet to port 23 but nothing. Have not nmapped it.
GS724TS
HardWare=00.00.01
BootVersion=1.0.1.5
Software=V5.2.0.10 - kofiAspirantDo an nmap and you'll detect the open port in the upper range. - At least other smart switches down to the 8-Port models what I can tell. Look for "Netgear switch hidden CLI" and you should at least find 1 or 2 people who have found it.
But beware: It seems there is a due cause why Netgear hinders us from using the CLI: It can crash the switch on certain commands. They are sold (and hopefully) test for Web-based administration but the CLI part may or may not work and is not tested. - rjtTutorPort 60,000 telnet switchTenFeetUp.MyNetwork 60000
