darrenscott
Dec 20, 2016Guide
GS724Tv3 does not boot after firmware update
I recently purchased another used GS724Tv3 switch from eBay (I already have 2 others) and was in the process of updating the firmware to the latest 5.4.2.25 version through the web GUI as I have done...
- Apr 24, 2017
I was in the same boat as you after bricking my GS724Tv3, and fortunately I found someone in the Netherlands who had a blog describing how to fix the issue. Netgear claims that there isn't a UART port on the device, but there actually is. Using a USB to TTL/Serial converter (runs you about $7 on Amazon), you can use a terminal program like PuTTy to access the switch, and flash over the original firmware for the device. From there, its a simple matter of using the GUI to work your way up the firmwares (making sure to flash all of the main revisions) and then you can get to the latest firmware.
HERE is the link to that webpage. If for some reason the link fails, do a search for Duteweerd Elektronica Reparatieverslag - Netgear GS724T V3 (English) and you can find step by step instructions.
DaneA
Dec 21, 2016NETGEAR Employee Retired
Hi darrenscott,
Welcome to the community! :)
It is not recommended to update the firmware from v4.1.0.9 then jump to the latest v5.4.2.25. The boot code should be updated as well when transitioning from the v4.x.x.x firmware to the v5.x.x.x firmware as indicated on this article. For me, it is more advisable to update the firmware in a ladderized manner. For example, since the current firmware is v4.1.0.9, you may update it to v4.2.0.11 then to v4.2.15 and so on until you reach the latest v5.4.2.25.
Kindly try to perform a factory reset on the GS724Tv3 then check if it would boot up normally. Observe the LED lights. If ever it boots up normally, check if you could still access its web-GUI. Let us know the results.
DaneA
NETGEAR Community Team
darrenscott
Dec 21, 2016Guide
Hi DaneA
Thanks for your reply.
I wasn't aware of the limitations on upgrades to the firmware prior to attempting it - there is no mention of it in the release notes for 5.4.2.25, and I've never had any problems upgrading any previous GS724Tv3 switches I have. Had I known in advance I would have performed a stepped upgrade as suggested.
I've tried a factory reset on the switch several times and on restart it results in the power LED staying amber rather than green. I assume by factory reset you mean holding in the factory defaults button for a few seconds? If so, this appears to have no effect as the switch results in the amber power LED.
Is there anything else I can do to restore this switch to working order?
Thanks again for your assistance.
Regards
Darren
