darrenscott
Dec 20, 2016Guide
GS724Tv3 does not boot after firmware update
I recently purchased another used GS724Tv3 switch from eBay (I already have 2 others) and was in the process of updating the firmware to the latest 5.4.2.25 version through the web GUI as I have done...
- Apr 24, 2017
I was in the same boat as you after bricking my GS724Tv3, and fortunately I found someone in the Netherlands who had a blog describing how to fix the issue. Netgear claims that there isn't a UART port on the device, but there actually is. Using a USB to TTL/Serial converter (runs you about $7 on Amazon), you can use a terminal program like PuTTy to access the switch, and flash over the original firmware for the device. From there, its a simple matter of using the GUI to work your way up the firmwares (making sure to flash all of the main revisions) and then you can get to the latest firmware.
HERE is the link to that webpage. If for some reason the link fails, do a search for Duteweerd Elektronica Reparatieverslag - Netgear GS724T V3 (English) and you can find step by step instructions.
darrenscott
Dec 21, 2016Guide
Hi DaneA
Thanks for your reply.
I wasn't aware of the limitations on upgrades to the firmware prior to attempting it - there is no mention of it in the release notes for 5.4.2.25, and I've never had any problems upgrading any previous GS724Tv3 switches I have. Had I known in advance I would have performed a stepped upgrade as suggested.
I've tried a factory reset on the switch several times and on restart it results in the power LED staying amber rather than green. I assume by factory reset you mean holding in the factory defaults button for a few seconds? If so, this appears to have no effect as the switch results in the amber power LED.
Is there anything else I can do to restore this switch to working order?
Thanks again for your assistance.
Regards
Darren
DaneA
Dec 21, 2016NETGEAR Employee Retired
Hi darrenscott,
Kindly try the steps below:
1. Disconnect the GS724Tv3 switch from your existing network and make sure its turned on. Get a straightened paper clip.
2. Insert the paper clip to the factory defaults hole then press and hold the factory reset button inside it for 30 seconds.
3. After 30 seconds, turn off the GS724Tv3 switch while you still continue to press and hold the factory reset button. Wait for 5 seconds.
4. After 5 seconds, turn on the GS724Tv3 switch while you still continue to press and hold the factory reset button. Wait for another 5 seconds.
5. After 5 seconds, release the paper clip from the factory reset button. Check if the GS724Tv3 switch to boot up properly. Observe the behavior of the LED lights.
DaneA
NETGEAR Community Team
- darrenscottDec 21, 2016Guide
Hi again DaneA
Thanks for the detail instructions.
I have tried this 5 times just now, all with the same outcome...
- on powering on the switch, the power LED shows amber and all port lights are on (both green and amber)
- after a few seconds the port lights go out leaving just the amber power LED
- after a few more seconds all port lights come back on for a further few seconds
- the port lights then go out again leaving the amber power LED again
Are the steps you describe meant to restore the switch to a known state again? Can you think why following these steps is not having any effect?
Regards
Darren
- DaneADec 21, 2016NETGEAR Employee Retired
Hi darrenscott,
Based on what you have observed, it seems that the GS724Tv3 switch got bricked that is why it won't boot up normally. You will need to have it replaced from the seller.
DaneA
Hi again and thanks for your continued assistance.
This is a used GS724Tv3 switch purchased on eBay, so there is no way I can get it replaced by the seller.
I find it amazing that it is possible to brick this switch by installing official firmware downloaded from the Netgear site, the release notes of which made no reference to having to perform the upgrade using any special instructions or installing earlier version of the firmware first! I have carried out the upgrade as instructed by Netgear yet it has left my switch bricked.
Is there really no way to recover this switch other than getting it replaced?
Do you work for Netgear or are you just a (very helpful) Netgear community member?
Do Netgear staff monitor these forums?
Regards
Darren
