darrenscott
Dec 20, 2016Guide
GS724Tv3 does not boot after firmware update
I recently purchased another used GS724Tv3 switch from eBay (I already have 2 others) and was in the process of updating the firmware to the latest 5.4.2.25 version through the web GUI as I have done...
- Apr 24, 2017
I was in the same boat as you after bricking my GS724Tv3, and fortunately I found someone in the Netherlands who had a blog describing how to fix the issue. Netgear claims that there isn't a UART port on the device, but there actually is. Using a USB to TTL/Serial converter (runs you about $7 on Amazon), you can use a terminal program like PuTTy to access the switch, and flash over the original firmware for the device. From there, its a simple matter of using the GUI to work your way up the firmwares (making sure to flash all of the main revisions) and then you can get to the latest firmware.
HERE is the link to that webpage. If for some reason the link fails, do a search for Duteweerd Elektronica Reparatieverslag - Netgear GS724T V3 (English) and you can find step by step instructions.
-c0de-
Apr 24, 2017Tutor
No problem. I was pretty frustrated when it bricked one, and relieved when I was able to get it working again. Just remember to connect TX to RX, and RX to TX when using the USB serial converter.
darrenscott
Apr 26, 2017Guide
I'm happy to report that my switch now lives again!
I did have a bit of trouble getting a serial console connecting to it from my MacBook Pro despite connecting the GND, TX and RX pins of the FTDI USB to serial cable to the J1 header. This was for a couple of reasons:
1. I was connecting at 115200 baud (which is what I've used to connect to other switches in the past) rather than the expected 9600
2. My USB to serial cable appeared to be defective! Thankfully I had a second identical cable which worked first time
To diagnose the 9600 baud problem I ended up connecting up a Saleae Logic analyser to it and monitoring the output on the TX pin during startup. It clearly showed activity, but was gibberish at 115200 baud. It was only when I switch the serial protocol analyser to use 9600 baud that it showed the expected output.
Once I'd got the serial console open and started the in-built TFTP server on the Mac, it was pretty straight forward to then flash the 4.1.0.9 firmware (although this did take a few minutes to complete, so don't be worried if it takes longer than you expect).
Thanks again for helping me bring this switch back from the dead :-)
- jditto1Jul 21, 2017Aspirant
Darren,
I noticed you said you were using a protocol analyzer. which one? what settings?
I've connected to my switch with a usb to serial converter and managed to get output to hyperterminal and putty. however all i get is gibberish. i've made sure that i've connected at 9600 to match prior posts. but i just get gibberish.
can you advise?
thanks,
joe
- JohnC_VJul 21, 2017NETGEAR Employee Retired
Hi jditto1,
Welcome to the community!
It seems that this post is too old already. Please feel free to create a new thread.
