BLogan
Dec 09, 2019Aspirant
GS724Tv3 on old firmware
I have the above mentioned switch which for the last few years has been used as a dumb switch in default configuration. It's been solid since the original install so i've never bothered doing anythin...
- Dec 11, 2019
Have a nice day,
see PDF on page 255 for Dual Image Configuration description.
On page 256 of the same PDF file is what you need.
Find out which Image you have active there.
https://www.downloads.netgear.com/files/GDC/GS716TV3/GS716Tv3_GS724Tv4_GS748Tv5_SWA_25Sept2013.pdf
schumaku
Dec 09, 2019Guru - Experienced User
Uploading the firmware alone isn't everything - depending on the storage area you need to select which of the two storage areas (Primary or Secondary) to boot.
BLogan
Not sure I understand fully, are you saying there is a choice of storage space where the firmware is stored.
- hacesoftDec 11, 2019Tutor
Have a nice day,
- BLoganDec 11, 2019AspirantThanks
