joliveira-kbc's avatar
Apr 20, 2020
GS724Tv4 - top speed 100Mbps
Dear Community,   I have a GS724Tv4 which has the latest firmware version: Product Name GS724Tv4 ProSafe 24-port Gigabit Ethernet Smart Switch, 6.3.1.34, B1.0.0.4 Serial Number 3H024B56002CC Bas...
  • joliveira-kbc's avatar
    joliveira-kbc
    Apr 26, 2020
    Hi Schumaku,
    Problem was on Ubuntu's 18.04 driver - autonegotiation was failing. Setting up 1000 Mbits full duplex on nic settings fixed the problem.
    Thank you for your help.
    Kind regards,
    Jose
ProSupport for Business
