joliveira-kbc
Apr 20, 2020Aspirant
GS724Tv4 - top speed 100Mbps
Dear Community, I have a GS724Tv4 which has the latest firmware version: Product Name GS724Tv4 ProSafe 24-port Gigabit Ethernet Smart Switch, 6.3.1.34, B1.0.0.4 Serial Number 3H024B56002CC Bas...
- Apr 26, 2020
Hi Schumaku,
Problem was on Ubuntu's 18.04 driver - autonegotiation was failing. Setting up 1000 Mbits full duplex on nic settings fixed the problem.
Thank you for your help.
Kind regards,
Jose
schumaku
Apr 21, 2020Guru - Experienced User
The link speed on the ports in the data path indicate full Gigabit (Speed LED: green) or Fast (Speed LED: amber)?
joliveira-kbc
Apr 26, 2020Aspirant
Hi Schumaku,
Kind regards,
Jose
