dharmgolf
Feb 06, 2022Aspirant
GS724Tv4 Disable HTTP Admin Access Required
Greetings, We are deploying severl of these Netgear GS724Tv4 switches (if we can figure this out) to end point remote offices, but we need to disable HTTP access for security and compliance. I ha...
JeraldM
Feb 08, 2022NETGEAR Employee Retired
Welcome to the community!
To disable HTTP Admin Access on your GS724Tv4, please set the timeout fields to 0.
For your reference, kindly check page 188 of the user manual here.
Please let us know if you encounter any issues.
JeraldM
NETGEAR Community Team
- dharmgolfFeb 08, 2022Aspirant
That does not work either. Just tried.
- JeraldMFeb 08, 2022NETGEAR Employee Retired
Hi dharmgolf,
If that's the case, you can try using Access Rule Configuration which is located on Security > Access.
You'll need to create an Access Profile first before setting a rule where you deny http on your local network.
Please refer to page 185 of the same user manual for more information.
JeraldM
Thank you and that is what I was thinking. I was wanting to provide a range of IPs but it looks like I have to Deny on a per IP Address. I will update and document. Thank you.
