alew
Aug 18, 2024Follower
GS724Tv4 Network Instability
My configuration is GS724Tv4 ProSafe 24-port Gigabit Ethernet Smart Switch connected to a Firewalla Gold router and two 1 GB Internet feeds coming into Firewalla Gold (Fios and Optimum). The Fios is...
Aug 29, 2024Guru - Experienced User
I would log into the Switches web ui and check around for any features seen on the web pages for Loopback Detection. Should be a enable or disable button.
Check to see if any FW is available for the switch as well.
