ATeamAdam
Mar 23, 2020Guide
Orbi RBR50 - instability issues
My kids have been complaining about our wifi for 2 years. Now that I'm working from home I'm feeling their pain. I've rebooted my router probably a dozen times in the last week.
Purchased October 2017
Firmware:
2.5.1.8
1 base station + 2 satellites
This is generally what happens:
Wifi will stop working, the orbi app says the internet is offline. I call my ISP and they confirm that the internet is infact online and working properly. When I try the internet speed test in the orbi app it does still return a good result. I reboot the router and everything starts working again. I think it's only wireless connections that have the major issues. The wired connected devices will still connect to the internet, although not well. I can get to google, I can get search results, but I can't get any of the links in the results to work.
Now after reboot, in the orbi app it is showing no devices connected, even though I know there are plenty connected. The traffic meter is enabled, but is showing no results.
I disabled circle yesterday and that seems like it is helping with stability.
I'm getting no indicator lights flashing on the orbis for any of these issues. When I reboot it flashes white while it is booting up, but it eventually goes away.
I haven't tried restoring to factory defaults yet. I'll try that next time it goes down.
Is my router dying?
Thanks for the quick insight. Appreciate the guidance.
Any Wifi Neighbors near by? If so, how many? I do have a few wifi neighbors, depending on where you are in the house you can see about a half dozen signals, most of them are pretty weak.
I setup these settings after the factory reset. Hopefully it goes smooth.
New config:
2.4 Ghz Channel - 6
5 Ghz Channel - 48
Beamforming - enabled
MIMO - enabled
WMM - enabled
Armor - disabled
Circle - disabled
Daisychain - disabled
Fast Roaming - disabled
IPv6 - disabled
20/40 mhz coexistence - disabled
Short preable - enabled
ATeamAdam wrote:Is my router dying?
Probably not, but it might be "sick". There seem to be two "camps" of Orbi users who have updated firmware to 2.5.1.8
- For some of us, it "works great". Same as always.
 - For others, it is a "living nightmare" of issues such as you describe. There are very long posts about 2.5.1.8 that you can read through.
So, yes, a "Factory Reset" is one possibility. Save the configuration to your computer. (On the Advanced Tab, Administration, Backup Settings. Do the Factory Reset: https://www.youtube.com/watch?v=cMw4ePACgc4 When it comes up and is ready to configure, say that you want to "Reload a previous configuration". This is a relatively painless reset method.
If the issue persists, then it may be necessary to reconfigure the Orbi, which for me is over an hour of drudgery because I have made so many setting and assignments.
If the issue still persists, some people download firmware 2.3.5.30 from the Netscape support web site and do a Manual Firmware update (actually "down-date").
Sorry not to have better news.
- MichaelCazAspirantHow did you get to the Netscape support web and complete the "down-date" of your system?
Instructions:
Router Firmware:
https://www.netgear.com/support/product/RBR50.aspx#download
Satellite Firmware:
https://www.netgear.com/support/product/RBS50.aspx#download
Keep in mind my links are only for the RBR50 router, and the RBS50 satellites. Your models may be different.
 - tomschmidtVirtuoso
Late last year Netgear released v2.5.0.x firmware, which had major issues. It also appears to have messed up the flash memory for some configuration items such that rolling back to v2.3.x releases or forward to v2.5.1.8 caused random issues. If your router ever had the v2.5.0.x firmware, then the only way to clear its corruption of the flash memory is to perform a factory reset.
I suggest taking screenshots or printouts of each of your configuration pages that you customized, that way you can manually reconfigure the router again to the same configuration after the factory reset.
Good Luck.
Appreciate the insights. I'll try the factroy reset tomorrow.
Is there a place I can look for best practices on manually configuring the Orbi? I have been running a pretty vanilla configuration and I figure this will be a good time evaluate better options.
After doing a reset, and setting up from scratch. Be sure to save off a new backup configuration to file for safe keeping. Saves time when a reset is needed.
Some other troubleshooting suggestions to help with instability issues:
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
https://community.netgear.com/t5/Orbi/Orbi-model-RBR50-keeps-dropping-connection-during-Zoom-calls/m-p/1874136/highlight/true#M84647
ATeamAdam wrote:Appreciate the insights. I'll try the factroy reset tomorrow.
