LVCLVC
Apr 07, 2022Aspirant
GS724Tv4 VLAN Routing
Hi, I've configured two VLANs on my switch and they are working as expected (can ping within each VLAN but not between the two), but I'm trying to figure out how to route traffic between them. ...
Retired_Member
Apr 08, 2022
I'm not familiar with the GS724Tv4 and my switches actually learn those routes themself, but I would set the Route Type to 'Static' instead of 'Connected'. Also, have you enabled the Routing Mode?
LVCLVC
Apr 11, 2022Aspirant
Thanks for the suggestions, and I believe I've enabled the routing mode, but I'll take a look at that and see if it will let me change the Route Type to 'Static' instead of 'Connected'.
