crodrig
Sep 05, 2023Aspirant
GS724Tv4 VLAN Routing
NetGear Community, I have a NetGear GS724Tv4 24 Port Gigabit Smart Switch in which I have configured 4 VLANS. I am only using VLAN1 and VLAN4 with VLAN 2 | VLAN3 as the default VLAN's (VOIP,...
michaelkenward
Sep 06, 2023Guru - Experienced User
This place is for talk about SMART Wi-Fi, General and Legacy Routers. While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Smart / Plus / Click Switches - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- crodrigSep 06, 2023Aspirant
Michael,
Thank you for reaching out.
I have read the user's manual for the GS724Tv4 Smart switch and not found a solution. I also believe it may be my naive understanding of Smart switches and lack thereof.
Thanks again.
