crodrig
Sep 06, 2023Aspirant
GS724Tv4 VLAN Routing
NetGear Community, I have a NetGear GS724Tv4 24 Port Gigabit Smart Switch in which I have configured 4 VLANS. I am only using VLAN1 and VLAN4 with VLAN 2 | VLAN3 as the default VLAN's (VOIP,...
- Sep 11, 2023
NetGear Community,
I have decided to install a second PCIe ethernet card on the server/workstation to be used as a rsyslog server for receiving syslog messages (UDP packets) from the GS724Tv4 Smart Switch logging service.
I basically configured the second ethernet card (eth1) on a separate subnet to communicate over the Management VLAN (VLAN1).
The primary ethernet card (eth0) is connected to VLAN4 which allows for inter-connecting workstations as a localized LAN.
The main goal is to provide network isolation between the user space and management space.
I hope this helps some helpless souls.
schumaku
Sep 08, 2023Guru - Experienced User
crodrig wrote:
The issue is that the syslog server has only one ethernet card and must receive network packets/data from VLAN 4 as well as from VLAN1 to meet DISA STIG Requirements of logging NetGear GS724Tv4 server log events..
Curious what syslog messaged from the GS724Tv4 you expect to receive on the management VLAN (VLAN 1 by default) -and- the access ports on VLAN 4 in your example?
