crodrig
Sep 06, 2023Aspirant
GS724Tv4 VLAN Routing
NetGear Community, I have a NetGear GS724Tv4 24 Port Gigabit Smart Switch in which I have configured 4 VLANS. I am only using VLAN1 and VLAN4 with VLAN 2 | VLAN3 as the default VLAN's (VOIP,...
- Sep 11, 2023
NetGear Community,
I have decided to install a second PCIe ethernet card on the server/workstation to be used as a rsyslog server for receiving syslog messages (UDP packets) from the GS724Tv4 Smart Switch logging service.
I basically configured the second ethernet card (eth1) on a separate subnet to communicate over the Management VLAN (VLAN1).
The primary ethernet card (eth0) is connected to VLAN4 which allows for inter-connecting workstations as a localized LAN.
The main goal is to provide network isolation between the user space and management space.
I hope this helps some helpless souls.
schumaku
Sep 08, 2023Guru - Experienced User
There are still no management access vectors on this VLAN.
crodrig
Sep 11, 2023Aspirant
NetGear Community,
