Erik-NA
Aug 14, 2016Aspirant
GS728TP managment IP-adress leased through DHCP even if static address is configured
I have configured the switch to use static IP-address for managment using a separate VLAN, VLAN 123. The web gui is accessible through this IP-adress. For unknwon reason, the switch is leasing an ma...
- Aug 14, 2016
Thanks for you suggestion. I solved it another way.
1. Changed managed VLAN id to 1.
2. Changed port to VLAN 1 and logged in, saw that default gateway field was empty. Inserted correct parameter and applied.
3. Changed back to original managed VLAN id
4. Problem solved.
I couldn't change to DHCP, got an error. But this did it
DaneA
Aug 14, 2016NETGEAR Employee Retired
Hi Erik-NA,
Welcome to the community! :)
Kindly try the steps below:
a. On the web-GUI of the GS728TP switch, go to System > Management > IP Configuration.
b. Select Dynamic IP Address (DHCP) then click Apply.
c. Select Static IP Address then re-enter the static IP Address you've assigned as well as the Subnet Mask and Default Gateway.
d. Click Apply.
e. Observe if same problem occurs.
Let us know the results.
DaneA
NETGEAR Community Team
- Erik-NAAug 14, 2016Aspirant
4. Problem solved.
- DaneAAug 15, 2016NETGEAR Employee Retired
Hi Erik-NA,
I'm glad that the problem is now resolved. :) I appreciate that you have shared the steps you did to solve the problem.
Feel free to post your future concerns here in the community.
DaneA
- Erik-NAAug 15, 2016Aspirant
No, problem
I think this happened when configuring management after factory reset by changing all parameters at once, both static IP-address, gateway and VLAN Id.
I belive that the process should be to first set static IP-address and gateway and then apply and after that change VLAN Id.
