Erik-NA
Aug 14, 2016Aspirant
GS728TP managment IP-adress leased through DHCP even if static address is configured
I have configured the switch to use static IP-address for managment using a separate VLAN, VLAN 123. The web gui is accessible through this IP-adress. For unknwon reason, the switch is leasing an ma...
- Aug 14, 2016
Thanks for you suggestion. I solved it another way.
1. Changed managed VLAN id to 1.
2. Changed port to VLAN 1 and logged in, saw that default gateway field was empty. Inserted correct parameter and applied.
3. Changed back to original managed VLAN id
4. Problem solved.
I couldn't change to DHCP, got an error. But this did it
Erik-NA
4. Problem solved.
DaneA
Aug 15, 2016NETGEAR Employee Retired
Hi Erik-NA,
I'm glad that the problem is now resolved. :) I appreciate that you have shared the steps you did to solve the problem.
Feel free to post your future concerns here in the community.
DaneA
NETGEAR Community Team
