Budgie4
Sep 14, 2021Tutor
GS728TPPv2 M4100-24PoE+ Port PVID question with two vlans
I have set up two vlans with different subnets with dhcp and dns enabled on my UTM. These are both set on one port on the UTM. When I connect this port to my switch I have to configure the switch p...
schumaku
Sep 14, 2021Guru - Experienced User
You can configure the trunk port for the UTM<->Switch link on both sides as tagged for all VLANs, or you can keep _one_ VLAN untagged with the same PVID obviously.
