Bazli
Feb 19, 2021Follower
GS728TPPv2 PoE Configuration Loading page
The PoE Configuraiton page and Advanced page just keeps loading. PoE itself appears to be working. Just can't load the configuration page. Other pages are fine. It happens in firefox and chrome. Any ...
DaneA
Mar 02, 2021NETGEAR Employee Retired
Welcome to the community! :)
Let us try this. Kindly upgrade the firmware to the latest version which is v6.0.6.2. You can download it here. Then, check if the same problem occurs.
You may want to perform a factory reset after upgrading the firmware in order to start clean using the latest firmware version.
DaneA
NETGEAR Community Team
