BillyLee
Mar 08, 2024Guide
GS728TXP (S3300-28X-PoE+) EOL Bonjour/mDNS issue
Hi: Recently got a project relate with EOL switch S3300 for mDNS service. It seems mDNS didn't run through uplink to other switches. I googled and found there seems to be a firmware 6.6.4...
BillyLee
Mar 11, 2024Guide
Hi Rene:
Thank you !
This is the file which mentioned before to solve the issue.
I will use this to apply and provide feedback.
Sincerely,
Billy Lee
BillyLee
Mar 12, 2024Guide
Hi
Just upgrade 2 of switches to test.
Found ineresting issue that it does forward mDNS now to uplink, but only for ipv6 address, not for ipv4 mDNS multicast.
Current setup is flat VLAN 1, with IGMP snooping ENABLE/check IGMP header ENABLE.
No Quierier or mRoute enabled.
Is there any setting is required to pass ipv4 mDNS 224.0.0.251 multicast to uplink ?
Sincerely,
Billy Lee
- ReneDMar 13, 2024NETGEAR Moderator
Hello schumaku,
Usually for a Netgear product that is EOL, there is no guarantee Engineering team are to release an official firmware. It will be best to open a support case for the specific device so Engineering can build a firmware same as what was provided on this thread.
Can you try to enable mrouter on the uplink port and see if the mdns will pass?
Have a lovely day,
Rene D
Netgear Team
