BillyLee
Mar 08, 2024Guide
GS728TXP (S3300-28X-PoE+) EOL Bonjour/mDNS issue
Hi:
Recently got a project relate with EOL switch S3300 for mDNS service.
It seems mDNS didn't run through uplink to other switches.
I googled and found there seems to be a firmware 6.6.4.29 solved this issue, but not been released.
I wonder if anyone can share this version ?
or any alternative way to configure for mDNS 224.0.0.251 to go through uplink to other switches ?
Currently IGMP snooping is enabled for IPTV channels and only 1 flat VLAN.
Sincerely,
Billy Lee
Hello BillyLee,
Did you solve your problem? In this case could you give us a feedback on the situation and accept the
post as a solution to make it more visible to other users?Thanks in advance! 🙂
Have a lovely day,
Rene D
Netgear Team
- Chris_PehAspirant
- BillyLeeGuide
Hi Rene:
Thank you !
This is the file which mentioned before to solve the issue.
I will use this to apply and provide feedback.
Sincerely,
Billy Lee
ReneD DavidGo Can this .29 build be made available on all S3300 models: S3300-28X (GS728TX), S3300-28X-PoE+ (GS728TXP), S3300-52X (GS752TX), and S3300-52X-PoE+ (GS752TXP) - so it will be available in the future on https://netgear.com/support please?
As the community is unable to reply here (and the Netgear reps tend to stay the same, or simply fail to locate or allocate internal resources): Open a ticket on https://www.netgear.com/about/contact-us/ - call (or email) them, whatever is available in your market. Sad but true.
