PdClark
Jul 20, 2018Tutor
GS748T no radius authentication
Hi
I have a Windows Server 2012 configured with NPS and is working fine with WiFi access points.
I'm trying to configure my GS748T to authenticate EAP with the server. What I've done so ...
- Jul 25, 2018
** Solved **
One thing I overlooked. Windows 7 and onwards have a service ' Wired AutoConfig' which is set to manual as default.
Set this to automatic and it works perfectly!
DaneA
Jul 23, 2018NETGEAR Employee Retired
Welcome to the community! :)
I am not sure if this will help. Let me share the forum link below and it might help:
DaneA
NETGEAR Community Team
PdClark
Jul 24, 2018Tutor
Hi Dane
Thanks for the reply.
I followed the link and sub-links on the articles and I've tried all the settings which were listed, with no sucsess.
The only time the switch contacts the Radius server is for authentication of the managment console. At no point does it try to contact the server for 802.1x authentication.
I've run a network monitor on the radius server and the only packets received from the switch are those from the console authentication.
I've checked the logs on the switch and there's nothing in there.
Very frustrating
