PdClark
Jul 20, 2018Tutor
GS748T no radius authentication
Hi
I have a Windows Server 2012 configured with NPS and is working fine with WiFi access points.
I'm trying to configure my GS748T to authenticate EAP with the server. What I've done so ...
- Jul 25, 2018
** Solved **
One thing I overlooked. Windows 7 and onwards have a service ' Wired AutoConfig' which is set to manual as default.
Set this to automatic and it works perfectly!
PdClark
Jul 24, 2018Tutor
In Port Authentication - Advanced it states EAP Protocol version 1, which I belive to be EAP-TTLS1.
I understand you can encapsulate PAP in EAP-TTLS1, which is what I've done dor our laptops 801.3 network policy.
But what i'm really confused with is that the switch doesn't send any data to the Radius server unless it's to authenticate the console logon.
PdClark
Jul 25, 2018Tutor
** Solved **
