PdClark
Jul 20, 2018Tutor
GS748T no radius authentication
Hi
I have a Windows Server 2012 configured with NPS and is working fine with WiFi access points.
I'm trying to configure my GS748T to authenticate EAP with the server. What I've done so ...
- Jul 25, 2018
** Solved **
One thing I overlooked. Windows 7 and onwards have a service ' Wired AutoConfig' which is set to manual as default.
Set this to automatic and it works perfectly!
PdClark
Jul 30, 2018Tutor
From my configuration;
On the switch, keep the Authentication List to Radius, Local, None. It enables all authentication to the Radius server including the console logon.
In Group Policy, set the wired config to use 'Smartcard or other certificate' and 'Computer only' authentication.
On the properties of 'smartcard or other cert', select 'Use a cert on my computer' click Advanced and select the root certificate issued from your CA.
On your NPS server, add the switch as a Radius client, create a 'Network Request' policy based on Domain Computers (or any other group for your computers) and a 'Client Friendly name'
Add a Network Policy adding the same group of computers and EAP type.
That should get you going. Tweek NPS to improve the constraints.
George_58
Aug 03, 2018Aspirant
No way :-/ . Problem 1 - not working and problem 2 not working..
Problem 1 - authentication to admin console. NPS server get request from switch and accept it - averything seems ok. But switch not allow to log in - why?
Problem 2 - any data on NPS server from workstation. It seems that no data go thru switch to NPS server. Why? Where can I find any information about this? In log on switch there is no datas about EAP from workstation.Only
| 03 Aug 2018 10:31:40%STP-W-PORTSTATUS: g15: STP status Forwarding |
| 03 Aug 2018 10:31:36%LINK-I-Up: g15 |
| 03 Aug 2018 10:31:31%LINK-W-Down: g15 |
It is problem of Radius attributs? Is there any document where can I find info about atributs which Netgear "must receive"?
I have .cer file from ma domain controller, but it contains no private key.So must I make new certificate, e.g. with Openssl, whitch will hace Public and Private keys?
Did you setup certificate on Netgear switch (Security/Access/HTTPS/Certificate management)? Or it can be blank.. sorry for too many questions, but I'am not network proffesional..
