siptash
Apr 21, 2021Aspirant
GS748TPS ports 1-24 won’t communicate with ports 24-48
Some strange thing happening in this switch. Hope someone can help. The first 24 ports communicate with each other fine. But they don’t communicate with ports 25 to 48. I can only access the swi...
JohnC_V
Apr 23, 2021NETGEAR Employee Retired
Welcome to our community! :)
It seems that you are trying to communicate with the other 24 ports from your switch. It would be best if you will check the VLAN membership page and check if ports 25-48 are assigned to a different VLAN and go to PVID Configuration and check if they are on the same PVID. This should resolve the issue once everything is on the same network.
John
NETGEAR Community Team
siptash
Apr 23, 2021Aspirant
I’ve reset the switch. Owing this reset any Vlans? When I look at the vlan options I only have 1 listed, the default one.
I’ll give what you said a go on Monday though.
