AdaMich
Oct 03, 2016Aspirant
gs748ts mac based port security
Trying to set up the switch (firmware version 5.2.0.11) as a basic managed switch and the only feature that needs to be enabled is mac based port security. I'd like to statically set the allowed ...
- Oct 03, 2016
Hi AdaMich,
On the web-GUI, go to Switching > Address Table > Advanced > Static Addresses. I believe you will need to enter the MAC address manually here and you can select which interface as well as set the status of it. Kindly read paged 4-53 to 4-54 of the GS748TS user manual here. Afterwards, configure Port Security.
Let us know the results.
DaneA
NETGEAR Community Team
DaneA
Oct 03, 2016NETGEAR Employee Retired
Hi AdaMich,
DaneA
