AdaMich
Oct 03, 2016Aspirant
gs748ts mac based port security
Trying to set up the switch (firmware version 5.2.0.11) as a basic managed switch and the only feature that needs to be enabled is mac based port security. I'd like to statically set the allowed ...
- Oct 03, 2016
Hi AdaMich,
On the web-GUI, go to Switching > Address Table > Advanced > Static Addresses. I believe you will need to enter the MAC address manually here and you can select which interface as well as set the status of it. Kindly read paged 4-53 to 4-54 of the GS748TS user manual here. Afterwards, configure Port Security.
Let us know the results.
DaneA
NETGEAR Community Team
DaneA
Oct 03, 2016NETGEAR Employee Retired
Hi AdaMich,
DaneA
AdaMich
Thanks for the response DaneA. That was exactly what I was missing.
For others that may run into the same issue, with the bost from DaneA, here is step-by-step what I did in my config that worked.
1 - Security > Traffic Control > Port Security > modified the port setting to 'Locked' and made note of the port name > Apply
2 - Switching > Address Table > Static Addresses > select the VLAN, enter the mac address, provide interface name, set status to 'Secure' > Apply
As per the manual, setting the port status to 'Secure' indicates the mac address is defined for a locked interface.
Thanks again DaneA for the bump.
- DaneAOct 04, 2016NETGEAR Employee Retired
Hi AdaMich,
I'm glad that you were able to configure it. :)
The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
