AdaMich
Oct 03, 2016Aspirant
gs748ts mac based port security
Trying to set up the switch (firmware version 5.2.0.11) as a basic managed switch and the only feature that needs to be enabled is mac based port security. I'd like to statically set the allowed ...
- Oct 03, 2016
Hi AdaMich,
On the web-GUI, go to Switching > Address Table > Advanced > Static Addresses. I believe you will need to enter the MAC address manually here and you can select which interface as well as set the status of it. Kindly read paged 4-53 to 4-54 of the GS748TS user manual here. Afterwards, configure Port Security.
Let us know the results.
DaneA
NETGEAR Community Team
AdaMich
Thanks for the response DaneA. That was exactly what I was missing.
For others that may run into the same issue, with the bost from DaneA, here is step-by-step what I did in my config that worked.
1 - Security > Traffic Control > Port Security > modified the port setting to 'Locked' and made note of the port name > Apply
2 - Switching > Address Table > Static Addresses > select the VLAN, enter the mac address, provide interface name, set status to 'Secure' > Apply
As per the manual, setting the port status to 'Secure' indicates the mac address is defined for a locked interface.
Thanks again DaneA for the bump.
DaneA
Oct 04, 2016NETGEAR Employee Retired
Hi AdaMich,
I'm glad that you were able to configure it. :)
The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
