CaCtus491
Jan 28, 2014Novice
GS748TS web interface issue when configuring LAGs
We have several GS748TS which need reconfiguration of the LAGs, however neither Chrome nor IE 10 (both normal and compatibility mode) appear to allow us to access the LAG configuration. In Google C...
- Mar 02, 2014Further searching, and in parallel NetGear Tech Support, pointed me to this KB:
http://kb.netgear.com/app/answers/detail/a_id/23841
I wonder how much time in aggregate has been wasted by how many NetGear customers like us since NetGear first knew of this issue? And they didn't even bother to update the docs, or include an Errata / Read This First slip?
Jeez, what an attitude.
SamirD
Feb 16, 2015Prodigy
I agree, although if they mess up, it's their own fault. The consumer side of third-party router firmwares has already sorted out that liability.
iam_TJ wrote: I will make sure the process is bullet-proof before I publish the details since I don't want other, probaby non-technical, folks bricking their devices! It will require use of specialised tooling on a Linux workstation.
I can't simply publish firmware images since, unless *everything* is re-written from scratch, it would infringe on the Netgear copyright - unless other device operators want to cooperate on an opne-source implementation :)
True, unless Netgear has used open source in their code. Also, you could just provide a custom service that someone needs to contact you--this way you control the distribution.
