CaCtus491
Jan 28, 2014Novice
GS748TS web interface issue when configuring LAGs
We have several GS748TS which need reconfiguration of the LAGs, however neither Chrome nor IE 10 (both normal and compatibility mode) appear to allow us to access the LAG configuration.
In Google Chrome, everything loads, except for the UI component to select ports to add / remove from a lag (Switching -> LAG -> LAG Membership). The same occurs for VLAN membership.
In Internet Explorer 10, the initial page after login doesn't even load correctly. With compatibility mode enabled, clicking on Switching -> LAG doesn't show the summary of the LAGs, however VLAN membership configuration works fine.
Any suggestions as to how we can manage the LAG configuration? A new firmware would be nice :)
Switch specifics from System -> Management -> System Information:
Model: GS748TS
Hardware Version: 00.00.01
Boot Version: 1.0.1.5
Software Version: V5.2.0.10
Model: GS748TS
- Further searching, and in parallel NetGear Tech Support, pointed me to this KB:
http://kb.netgear.com/app/answers/detail/a_id/23841
I wonder how much time in aggregate has been wasted by how many NetGear customers like us since NetGear first knew of this issue? And they didn't even bother to update the docs, or include an Errata / Read This First slip?
Jeez, what an attitude.
- iam_TJTutor
iam_TJ wrote: I will make sure the process is bullet-proof before I publish the details since I don't want other, probaby non-technical, folks bricking their devices! It will require use of specialised tooling on a Linux workstation.
As promised, the first half (extractor) of my ROS firmware toolkit is available. I've announced it in its own thread in these forums. Please test and provide feedback. - SamirDProdigy
Thank you for the release! I'm not well versed in linux, but if it's something pre-compiled, I might be able to give it a go.iam_TJ wrote: As promised, the first half (extractor) of my ROS firmware toolkit is available. I've announced it in its own thread in these forums. Please test and provide feedback. - kamilnerNoviceIt is ridiculous they won't fix this.
I wonder if there is a possibility to provide a user fix via something like Tampermonkey, rather than reflashing the firmware.
Cheers,
Keith
