Cannondella
Aug 29, 2019Tutor
GS748Tv4 getting constant power resets
Seeing low system uptime. Also seeing logs of that LAN port outage on our sonicwall interface. System Up Time 0 days 3 hours 46 mins 0 secs. Office is constantly losing LAN connection. Swith...
- Sep 08, 2019
What happens if there is a power flicker while im upgrading the firmware? Just to check on next steps are you able to send out a new switch if this doesnt work? What would that process look like, just want to have answers if they come up from an answering to manager perspective, thanks!
In the process of upgrading the firmware then suddenly a power interruption occurred, most probably the switch will get bricked. To make sure that the switch really got bricked, a hardware checked must be done. Then if ever the switch is proven faulty, NETGEAR will provide a replacement provided that your switch still has hardware warranty.
OK upgraded the firmware, but it seems as if the switch is still shutting down atleast once a day. How do I go about getting a replacement sent out?
Thanks for the update. Since the GS748Tv4 switch still shuts down on its own once a day, it is possible that it is a hardware fault. I suggest you to open a chat or online case with NETGEAR Support here at anytime. Kindly state what happened to your GS748Tv4 switch as well as you can include the link to this forum thread as reference. A NETGEAR Support expert will be assigned to your support ticket and will do a hardware check and if the switch is proven faulty, an online replacement will follow provided that your switch still has hardware warranty.
DaneA
NETGEAR Community Team
DaneA
Sep 05, 2019NETGEAR Employee Retired
C. Firmware version is 5.4.1.11, will try updating this after hours. Is 5.4.1.11-->5.4.2.30 an OK upgrade path? Thanks
You may upgrade the firmware directly from v5.4.1.11 to v5.4.2.30. Then, check if the same problem will occur.
Also, you may want to perform a factory reset on the GS748Tv4 after upgrading the firmware to the latest firmware version then reconfigure everything from scratch in order to start clean using the latest firmware version. Then, check if the same problem will occur.
DaneA
DaneA
Sep 08, 2019NETGEAR Employee Retired
DaneA
- CannondellaSep 10, 2019Tutor
Hasnt gone off since the firmware upgrade since friday night. Upgraded image 1 and image 2. So maybe this did fix the problem, thanks for the help.
