BestYohman
Aug 19, 2024Aspirant
GS748Tv5 managed switch with a Nest pro wifi
I have Nest pros with a Netgear GS748Tv5 managed switch. I have turned off stp and turned on forward BPDU. Everything was working fine until a about a month ago. When I connect the two Nest pros via ...
RennaD
Aug 21, 2024NETGEAR Moderator
Hello BestYohman,
Welcome to the NETGEAR Community! 🙂
Which port of the Nest Pro is connected to the switch? Kindly provide a network topology.
Do you have internet when you bypass the switch? Also, what is the switch firmware? I suggest to update it to the latest version 6.3.1.47, if not yet done.
Have a lovely day,
RennaD
Netgear Team
BestYohman
Aug 25, 2024Aspirant
I updated to the latest firmware. The network no longer goes to a crawl when they both are connected to the managed switch. The max speed I get is 440Mbps when they are connected though. When they are connected to the unmanaged switch I get on average 950Mbps
