BestYohman
Aug 19, 2024Aspirant
GS748Tv5 managed switch with a Nest pro wifi
I have Nest pros with a Netgear GS748Tv5 managed switch. I have turned off stp and turned on forward BPDU. Everything was working fine until a about a month ago. When I connect the two Nest pros via ...
BestYohman
Aug 25, 2024Aspirant
I updated to the latest firmware. The network no longer goes to a crawl when they both are connected to the managed switch. The max speed I get is 440Mbps when they are connected though. When they are connected to the unmanaged switch I get on average 950Mbps
RennaD
Aug 28, 2024NETGEAR Moderator
Hello BestYohman,
Do you get those speed through wireless clients or clients wired to the switch? Can you try to factory reset the switch (save the config in case you need to restore) then disable the STP and enable the "Forward BPDU while STP Disabled" again.
Have a lovely day,
RennaD
Netgear Team
