ClearSky
Apr 22, 2024Aspirant
GS750E change Management VLAN
Hello, i can't find the option to change the management VLAN. Under System -> Management -> Switch Information i can only change the IP. Where do i find it? I already configured two Tagged VLANs o...
- Apr 25, 2024
RennaD wrote:
GS750E is a Plus Switch and does not support Management VLAN by design.
This limitation isn't just because it's a Plus Switch model. Other Plus models (GSnnnE[xx]) or MSnnnE[xx]) are built on managed cores, nicely supporting the management VLAN.
Cumbersome, the Netgear KB does not properly reflect this differences: What is a management VLAN does falsely list all Plus Switches, where few do indeed come with management VLAN support. Most notably the MS108EUP, but also e.g. the XS724EM (another Plus switch certainly supporting the Management VLAN, as built on a managed core switch chip) listed under the [10 Gb Switch] models.
RennaD please push the PLM Iphie_C IphieChen to update these misleading product lists and KB entries. Thank you!
-Kurt.
schumaku
Apr 23, 2024Guru - Experienced User
Permitting it's configurable, there it should be (last line).
Have the last GS750E Firmware version 1.0.1.10 already in place?
ClearSky
Apr 24, 2024Aspirant
I upgraded the Firmware to Version 1.0.1.10, but the option is still not visible.
- RennaDApr 24, 2024NETGEAR Moderator
Hi ClearSky,
Welcome to the NETGEAR Community! 🙂
GS750E is a Plus Switch and does not support Management VLAN by design. If you have to configure Management VLAN you may want to consider the following NETGEAR switch models:
Smart Managed Switches:
https://www.netgear.com/hk-en/business/wired/switches/smart/
Smart Switches with Optional Insight Remote/Cloud Management:https://www.netgear.com/hk-en/business/wired/switches/smart-cloud/
Fully Managed Switches:https://www.netgear.com/hk-en/business/wired/switches/fully-managed/
Have a lovely day,
RennaD
NETGEAR Team- schumakuApr 25, 2024Guru - Experienced User
-Kurt.
