LukasO
Oct 27, 2021Aspirant
GS750E WebInterface does not load after update to 1.0.1.10
Hi Community,
anyone else having issues with the WebInterface being stuck at the "login" screen after updateing to version 1.0.1.10 ?
Both my GS750E do not load the webinterface after typing in the correct password. The UI returns to the login screen.
With an incorrect password the login area actually says "invalid password".
I am using the ESR Version of Firefox.
I had to install the ProSafe config utility to manage the switches, which at least works, but requires Windows OS.
Anybody with the same issue and/or a resolution?
Cheers Lukas
Instead if the "Enter" key as we're used to, please try to click the [Login] button.
- LukasOAspirant
Unfortuntelly,
no. It is not that easy. After clicking on "login" (with the correct password) the browser does POST requests ~ every second to:
"set.cgi?cmd=home_loginStatus&dummy=<EPOCH Timestamp>"
But the website does not change, stays on the login screen.
- LukasOAspirant
Verified same behaviour with latest MS Edge Browser.
- May 25, 2022Retired_Member
