IOTdiot's avatar
IOTdiot
Tutor
Mar 28, 2019
GS752TP v1 to v2 - Same backup file?
My GS752TP-100NAS (v1?) just stopped working and it seems Netgear is sending me a GS752TP-200NAS (v2?) as a replacement.   On the support page you can select v1/v2 and they have different firmwar...
  • IOTdiot's avatar
    IOTdiot
    Mar 29, 2019
    FYI for anyone wondering; I just manually reconfigured my new v2 switch. I did not use the v1 config or try to import it as the new webGUI looks different than the old one.
ProSupport for Business
