Debtless4941's avatar
Debtless4941
GS752TP firmware upgrade path
Hi All,
Is that any firmware upgrade path for upgrading on NETGEAR GS752TP from 6.0.1.18 > 6.0.1.30 ?
Can I upgrade directly from 6.0.1.18 to 6.0.1.30 ? or I have to upgrade step by step e.g. 6.0.1.18 > 6.0.1.24 >6.0.1.29....
Thanks for your advice.
##GS752T
#Firmware
#Upgrade
  • Hi Debtless4941,
    it's always a good thing, before upgrading, to read the release notes for each FW, which you can find as followed:
    Then, the release notes, should advise, on any upgrade path, if there is one to take.
    But, as we can see, there is no mention of following a specific path, therefore it should be safe to go from 6.0.1.18 directly to 6.0.1.30.
    Mike
  • MikeD1234's avatar
    MikeD1234
    NETGEAR Expert
    Hi Debtless4941,
    Mike
ProSupport for Business
