gusto77's avatar
gusto77
Firmware upgrade failed
I tried to update to the latest firmware tonight and halfway through the download it quit and showed an error icon. Now I can't do anything with the router. It won't connect to 192.168.1.1 (wired or unwired) so no chance to try the update again. I tried a factory reset, 30-30-30 reset, nothing helps. The power light is just continually blinking. Is it hopelessly dead?
