PhilaniG
Jun 10, 2023Aspirant
GS752TPV2 -DHCP Relay not working
Hi Community, I have a problem setting up DHCP relay on the Netgear GS752TPV2 switch. The scenario is this I have two VLANs, on PC VLAN and One Wifi VLAN. My DHCP server is on the PC VLAN b...
schumaku
Jun 10, 2023Guru - Experienced User
Configured (and enabled) the DHCP L2 Relay Global Configuration, configured (and enabled) the DHCP L2 Relay VLANs, and configured (and enabled) the DHCP L2 relay interfaces?
PhilaniG
Configured (and enabled) the DHCP L2 Relay Global Configuration - Yes, I've attached a snippet of what I configured.
configured (and enabled) the DHCP L2 Relay VLANs - Yes, please see attached snippet
configured (and enabled) the DHCP L2 relay interfaces? Yes.
I'm using VLAN 1(default) and VLAN 2 (static wifi)
port 11 (DHCP Server, part of VLAN 1)and port 12 (Wifi AP, part of VLAN 2) have both admin mode enabled.
furthermore
Port 11 is untagged on VLAN 1, tagged on VLAN 2
Port 12 is untagged on VLAN 2, tagged on VLAN 1
