lentilbean's avatar
lentilbean
Follower
Apr 05, 2019
GS752TPv2 Inter-VLAN routing
Hi.  Is inter-VLAN/subnet routing possible on a GS752TPv2 without the aid of a VLAN aware router?  The manual indicates it is, as do some other documents I found, but I have had no success.
Thanks.
Len
  • Of course all Smart Managed Pro switches with the L3 feature on board routing can do this. However, get rid of the "Inter-VLAN routing" idea - you have to design and set-up a proper static router IPv4 environment, using the appropriate default gateway, e.g. on each switch VLAN subnet.
1 Reply
  • schumaku's avatar
    schumaku
ProSupport for Business
