DougShuffield
May 21, 2019Tutor
GS752TPv2: POE enable / disable via SNMP
I noted there is an existing thread on this topic in german that ends with a private message (https://community.netgear.com/t5/Smart-Plus-Smart-Cloud-Switches/Switch-GS752TPv2-POE-Admin-enable-disabl...
- Jun 06, 2019
I bring this thread to conclusion and help anyone that has this issue in the future, my resolution was to purchase (for about $300 more than the GS752TPv2) the GSM7248P (M4100 Series) switch which supports the Power Ethernet MIB (RFC-3621).
Netgear, please do not remove RFC-3621 support from the GSM7248P!
Doug
schumaku
May 21, 2019Guru - Experienced User
The other post in English wans't enough, so there was a need to duplicate, too? https://community.netgear.com/t5/Smart-Plus-Click-Switches/GS724TPv2-POE-enable-disable-via-SNMP/m-p/1736130#M12255
