DougShuffield
May 21, 2019Tutor
GS752TPv2: POE enable / disable via SNMP
I noted there is an existing thread on this topic in german that ends with a private message (https://community.netgear.com/t5/Smart-Plus-Smart-Cloud-Switches/Switch-GS752TPv2-POE-Admin-enable-disabl...
- Jun 06, 2019
I bring this thread to conclusion and help anyone that has this issue in the future, my resolution was to purchase (for about $300 more than the GS752TPv2) the GSM7248P (M4100 Series) switch which supports the Power Ethernet MIB (RFC-3621).
Netgear, please do not remove RFC-3621 support from the GSM7248P!
Doug
schumaku
May 21, 2019Guru - Experienced User
The other post in English wans't enough, so there was a need to duplicate, too? https://community.netgear.com/t5/Smart-Plus-Click-Switches/GS724TPv2-POE-enable-disable-via-SNMP/m-p/1736130#M12255
DougShuffield
May 21, 2019Tutor
Same issue, different device. Are the GS724TPv2 and GS752TPv2 similar enough to share the same thread? If so, I can delete this one and post a reply in the other thread about the same issue with the 752.
Thanks.
Doug
Thanks.
Doug
- schumakuMay 21, 2019Guru - Experienced User
DougShuffield wrote:
Are the GS724TPv2 and GS752TPv2 similar enough to share the same thread?Oh Doug, Desperaterly sorry please, my bad - I was wrong by four ports! The GS728TPv2 / GS728TPPv2 / GS752TPv2 / GS752TPP share the same firmware, the GS724TPv2 is a different generation.
Christian_R one more similar question (or in fact two - looks like the GS728TPv2 / GS728TPPv2 / GS752TPv2 / GS752TPP don't list the Power MIBs, too).
- Retired_MemberMay 22, 2019
Currently, For GS728TPv2/GS728TPPv2/GS752TPv2/GS752TPP and GS724TPv2 switch, it's only support public mib node.
I will ask our R&D if there is plan to support Private mib node.Hope it helps!
EricZ
NETGEAR employee- schumakuMay 23, 2019Guru - Experienced User
I will ask our R&D if there is plan to support Private mib node.Not sure how to understand. public MIB == standard MIB, private MIB == vendor specific MIB?
But then, the Power-Ethernet-MIB is a standard one, isn't it?
