DougShuffield
May 21, 2019Tutor
GS752TPv2: POE enable / disable via SNMP
I noted there is an existing thread on this topic in german that ends with a private message (https://community.netgear.com/t5/Smart-Plus-Smart-Cloud-Switches/Switch-GS752TPv2-POE-Admin-enable-disabl...
- Jun 06, 2019
I bring this thread to conclusion and help anyone that has this issue in the future, my resolution was to purchase (for about $300 more than the GS752TPv2) the GSM7248P (M4100 Series) switch which supports the Power Ethernet MIB (RFC-3621).
Netgear, please do not remove RFC-3621 support from the GSM7248P!
Doug
DougShuffield
May 21, 2019Tutor
Same issue, different device. Are the GS724TPv2 and GS752TPv2 similar enough to share the same thread? If so, I can delete this one and post a reply in the other thread about the same issue with the 752.
Thanks.
Doug
Thanks.
Doug
schumaku
May 21, 2019Guru - Experienced User
Oh Doug, Desperaterly sorry please, my bad - I was wrong by four ports! The GS728TPv2 / GS728TPPv2 / GS752TPv2 / GS752TPP share the same firmware, the GS724TPv2 is a different generation.
Christian_R one more similar question (or in fact two - looks like the GS728TPv2 / GS728TPPv2 / GS752TPv2 / GS752TPP don't list the Power MIBs, too).
